1971 R75 /6 Cylinder Recondition/Nikasil Coating
Friends of MOA,
So first let me just say thanks for being such an amazing resource, I finally bucked up and bought my membership, as having 2 boxers in the garage (2106 R nineT, 1971 R50 /5) would like to start being a member of the community and giving back where I can. I am a Mechanical Engineer by education, been working on air-cooled engines since I was kid (VW's mostly, but the odd Honda Dream and Norton here and there) and am thoroughly enjoying the down to frame strip I am doing on my recent R50 acquisition. Introductions aside, on to my question....
Even thought the bike is a R50 /5, the previous owner at some point switched the engine/trans out to a R75 /6 (build date 01/74), and when I bought it had an unknown mileage and has been sitting on the side yard for 17 years. Anyway, after removing the heads and jugs/pistons, it is pretty evident there was a lot of blow-by and this engine has seen some miles and is in need of at the very least a top end refresh. Being as how it seems very difficult to find a new set, and doing a lot of reading, it seems the Nikasil cylinders are the way go which gave me three options; To either purchase one of the big bore kits, source a set 81-84 cylinders/pistons in good condition, or recondition and coat my existing cylinders. I opted for the latter for cost effectiveness, and reached out to Millennium Technologies and had a great talk with Jeff about the process, however was cautioned to not use chrome faced rings as it would damage the coating. That said, I need to source a set of rings for the 82mm pistons I have which will be compatible with the coating.
So, long story, short question, can I use the OEM replacement rings for this model R75 safely in my coated cylinders (details of the construction/material of rings seems hard to find), or is there another source for rings I should be looking at?
Thanks.
-Christian
Friends of MOA,
Thanks.
-Christian
