The bike belonged to my father who passed away last Sept. It's now my sons. He wants to ride it to the "Glen Rally" next Friday. BUT we can't get the turn signals to work. If the flasher unit is bad would the turn signal light at least come on BUT not flash? Signal lights don't even come on. Bike runs, head light high and low beam, and tail light work. Before dad passed away he tried to work on something in the head light assembly, but with dementia and alzheimer's things got a little messed up. I'm pretty sure I got all the wires back on correctly. It would help if I had a wiring diagram to read. I'm also thinking the switch would be bad. But those wires are all soldered. Any easy way to check that?
Also to adjust the valves- to get to TDC can I just bump the rear weal with the trans. in gear, or do I have to take off the front engine cover?
Hopping SOMEONE can help.
Mike 1der
PS the horn also does not work. Could just be that it is bad. If I was to run a wire from the battery +- (6v) directly to the horn it should blow, correct?
Mike 1der
