brook.reams
B Reams
Folks,
Well, it happens. I had a low speed tip over and cracked the upper fairing and broke one of the tabs that the left front turn signal screws into.
Sigh ....
I've used a product called Plast-aid to repair a broken Windjammer fairing wiring bulk head connection with great success and to So, used it on the BMW plastic which is likely ABS or a kissing cousin. I was very pleased with R1150-RS fairing repair.
I posted a blog about how I did the work on the R1150-RS here.
BMW Fairing Plastic Repair with Plast-Aid
It didn't take long and the repair seems to be as strong as the original plastic, so I'm very pleased with the result.
Here are some pictures of before and after.
<a title="Cracked Upper Fairing by Brook Reams, on Flickr" href="https://www.flickr.com/photos/brook-reams/17129576134"><img src="https://c2.staticflickr.com/6/5456/17129576134_af0222a10c_z.jpg" alt="Cracked Upper Fairing" width="640" height="426" /></a>
]<a title="Broken Tab for Turn Signal Mounting by Brook Reams, on Flickr" href="https://www.flickr.com/photos/brook-reams/17129576494"><img src="https://c2.staticflickr.com/6/5345/17129576494_d70129b8b8_z.jpg" alt="Broken Tab for Turn Signal Mounting Screw" width="640" height="426" /></a>
<a title="Reinforcing Washer Glued On by Brook Reams, on Flickr" href="https://www.flickr.com/photos/brook-reams/17565795729"><img src="https://c1.staticflickr.com/9/8835/17565795729_c20faac026_z.jpg" alt="Reinforcing Washer Glued On" width="640" height="426" /></a>
<a title="Final Repair-Just Needs Painting by Brook Reams, on Flickr" href="https://www.flickr.com/photos/brook-reams/17565795129"><img src="https://c1.staticflickr.com/9/8838/17565795129_f496e557a8_z.jpg" alt="Final Repair-Just Needs Painting" width="640" height="426" /></a>
Sigh ....
