brook.reams
B Reams
1977 R100RS Project: Front End Rebuild
I've posted a series of write-ups that cover rebuilding the front end of this bike. You can find them here:
<ul class="children">
<li class="page_item page-item-4997"><a href="http://brook.wordpress.reams.me/bmw-motorcyle-rebuilds/1977-bmw-r100rs-rebuild-project-index/31-bmw-1977-r100rs-remove-front-forks-handle-bars-steering-stem-fork-lock/">31 BMW 1977 R100RS Remove Front Forks, Handle Bars, Steering Stem, Fork Lock</a></li>
<li class="page_item page-item-5044"><a href="http://brook.wordpress.reams.me/bmw-motorcyle-rebuilds/1977-bmw-r100rs-rebuild-project-index/31-bmw-1977-r100rs-replace-steering-head-bearings-rebuild-front-forks/">31 BMW 1977 R100RS Replace Steering Head Bearings, Rebuild Front Forks</a></li>
<li class="page_item page-item-4999"><a href="http://brook.reams.me/bmw-motorcyle-rebuilds/1977-bmw-r100rs-rebuild-project-index/31-bmw-1977-r100rs-install-steering-stem-front-forks-and-toaster-tan-top-brace/">31 BMW 1977 R100RS Install Steering Stem, Front Forks and Toaster Tan Top Brace</a></li>
<li class="page_item page-item-5006"><a href="http://brook.wordpress.reams.me/bmw-motorcyle-rebuilds/1977-bmw-r100rs-rebuild-project-index/34-bmw-1977-r100rs-rebuild-and-restore-front-disk-brakes-master-cylinder/">34 BMW 1977 R100RS Rebuild and Restore Front Disk Brakes & Master Cylinder</a></li>
<li class="page_item page-item-4869"><a href="http://brook.wordpress.reams.me/bmw-motorcyle-rebuilds/1977-bmw-r100rs-rebuild-project-index/36-bmw-1977-r100rs-wheel-bearings-remove-install-adjust-preload/">36 BMW 1977 R100RS Wheel Bearings-Replace & Adjust Preload</a></li>
</ul>
These write-ups cover disassembly of the handlebars, forks, steering stem, steering damper and fork lock, rebuilding and restoring the wheels, wheel bearings, fork damper rods, fork sliders, steering stem bearings, fork lock, steering damper and installation of a new <a href="http://toastertan.com/top_brace/" target="_blank">Toaster Tan top brace</a> and steering stem "acorn" nut.
I also have a couple of short videos included that show how I measure fork stiction as I assemble the forks and braces and how I measure the fork tube aligment in the X and Y axis.
I also used<a href="https://spieglerusa.com/brakes/brake-lines-accessories-tools/cycle-brake-line-kits/bmw-r-100-rs-front-brake-line-kit-112.htm" target="_blank"> Speigler braided steel brake hoses</a>, stainless steel caliper brake lines from <a href="https://www.rockypointcycle.com/c-bmw.html" target="_blank">Rocky Point Cycle</a>.
Here is what I started with.
<a title="Torn Top Plate of Left Perch" href="https://www.flickr.com/photos/brook-reams/33197659105/in/album-72157680932474765/"><img src="https://c1.staticflickr.com/4/3911/33197659105_0e77f4049e_z.jpg" alt="Torn Top Plate of Left Perch" width="640" height="426" /></a>
<a title="Cover Plate Obstructs Lock Tumbler Preventing Removal" href="https://www.flickr.com/photos/brook-reams/33041689562/in/album-72157680932474765/"><img src="https://c1.staticflickr.com/4/3877/33041689562_65dd7496e7_z.jpg" alt="Fork Lock" width="640" height="426" /></a>
Fork Lock=
<a title="Front Wheel Left Side of Hub" href="https://www.flickr.com/photos/brook-reams/32374261866/in/album-72157677347336402/"><img src="https://c1.staticflickr.com/1/265/32374261866_4a9a36c416_z.jpg" alt="Front Wheel Left Side of Hub Showing Corrosion" width="640" height="480" /></a>
<a title="Master Cylinder Mounted on Spine Tube" href="https://www.flickr.com/photos/brook-reams/33460100486/in/album-72157675789624605/"><img src="https://c1.staticflickr.com/3/2853/33460100486_de9c98b3a6_z.jpg" alt="Master Cylinder Grunge and Rust" width="640" height="426" /></a>
<a title="Original Caliper is Faded" href="https://www.flickr.com/photos/brook-reams/33117746100/in/album-72157675789624605/"><img src="https://c1.staticflickr.com/3/2937/33117746100_210d1f30cc_z.jpg" alt="Original Caliper is Faded, Axle is Rusty, Fork Lowers Chipped" width="640" height="480" /></a>
<a title="Sign Friction Material Is Separating from Steel Backing Plate" href="https://www.flickr.com/photos/brook-reams/29975504673/in/album-72157675789624605/"><img src="https://c1.staticflickr.com/6/5530/29975504673_ccf692c497_z.jpg" alt="Friction Material Is Separating from Steel Backing Plate" width="640" height="426" /></a>
<a title="Exterior Fading" href="https://www.flickr.com/photos/brook-reams/29975501693/in/album-72157675789624605/"><img src="https://c1.staticflickr.com/6/5577/29975501693_0d6163e0e2_z.jpg" alt="Exterior Fading of Caliper Anodizing" width="640" height="426" /></a>
<a title="Telefix Fork Brace" href="https://www.flickr.com/photos/brook-reams/29995237771/in/album-72157673429384672/"><img src="https://c1.staticflickr.com/9/8675/29995237771_e21ac15b7d_z.jpg" alt="Telefix Fork Brace Needs Refinishing" width="640" height="426" /></a>
<a title="Fork Brace & Fender Mount" href="https://www.flickr.com/photos/brook-reams/29995236791/in/album-72157673429384672/"><img src="https://c1.staticflickr.com/6/5348/29995236791_cf8a9a09be_z.jpg" alt="Stock Fork Brace-Fender Mount" width="640" height="426" /></a>
Stock Fork Brace-Fender Mount[/caption]
And here is what I ended up with.
<a title="Fork Lock Installed" href="https://www.flickr.com/photos/brook-reams/32352784434/in/album-72157680932474765/"><img src="https://c1.staticflickr.com/3/2808/32352784434_39d020494b_z.jpg" alt="Fork Lock Installed in Powder Coated Frame" width="640" height="480" /></a>
<img src="https://c1.staticflickr.com/4/3896/32440292483_34b4fc2629_z.jpg" alt="Powder Coated Front Wheel with New Wheel Bearings Ready to Roll" width="640" height="480" />
<a title="Painted Control Housings" href="https://www.flickr.com/photos/brook-reams/32501103183/in/album-72157680932474765/"><img src="https://c1.staticflickr.com/3/2857/32501103183_52d219cecc_z.jpg" alt="Repaired & Painted Control Housings" width="640" height="480" /></a>
<a title="Master Cylinder Mounted on Spine Tube" href="https://www.flickr.com/photos/brook-reams/32772912504/in/album-72157675789624605/"><img src="https://c1.staticflickr.com/3/2921/32772912504_797faccf25_z.jpg" alt="Rebuilt and Refinished Master Cylinder Mounted on Spine Tube" width="640" height="480" /></a>
<a title="Toaster Tan Top Plate Mounted" href="https://www.flickr.com/photos/brook-reams/32615276323/in/album-72157673429384672/"><img src="https://c1.staticflickr.com/3/2837/32615276323_ec15f55f2e_z.jpg" alt="Toaster Tan Top Plate & Steering Stem "Acorn" Nut Mounted" width="640" height="480" /></a>
<a title="Toaster Tan Top Plage" href="https://www.flickr.com/photos/brook-reams/32586749574/in/album-72157673429384672/"><img src="https://c1.staticflickr.com/1/755/32586749574_50e1848898_z.jpg" alt="Toaster Tan Top Plate" width="640" height="480" /></a>
<a title="Stock Fork-Fender Brace" href="https://www.flickr.com/photos/brook-reams/33807460562/in/album-72157673429384672/"><img src="https://c1.staticflickr.com/4/3937/33807460562_67386b6915_z.jpg" alt="Stock Fork-Fender Brace Mounted on Rebuilt Forks" width="640" height="480" /></a>
<img src="https://c1.staticflickr.com/3/2928/33479600611_fc658c95a0_z.jpg" alt="Speigler Braided Steel & Rocky Point Cycle Stainless Aluminum Caliper Line" width="640" height="480" />
</ul>
Fork Lock=
