Having read a few threads recently about water intrusion into places it shouldn’t easily reminded me of some finds and probable causes talking to various owners.
The most common I have seen is water in the Paralever on a lot of R1200 and K12/13/1600 models. Sure, a lot of front boots are torn on GS’s and easy for water to get in that way, but a lot of in place, non-damaged boots also have had water when dropping final drive. In talking to the operators, none have driven in high water, however admitted to pressure washing the bikes close range.
On earlier 1100/1150’s the HES symptoms often are after a wash, though the insulation is going to fail at some point even in a rainy ride, so cannot use it as a root cause.
I admit on occasion I have stopped in a bay and sprayed crud off bikes… more often it’s a garden hose at 60 gpm on a good day. On the pressure washer it’s about three feet back and try to go in direction rain would normally travel front to back, more light spray than full blast! I never spray instrument cluster or ignition switch area.
Not the wash method police and not needing to hear you’ve done it that way for years Just throwing it out there that the bikes most likely designed with front to back rain in mind with connector orientation and water shedding abilities… just sayin’ it could be a factor. I’ve watched friends peel paint, vinyl, insulation and occasionally parts only to not have bike start up afterwards… only to look at me in a panic and delay the ride.
Was curious about speed at nozzle of average home pressure washer
Saw this
Don’t think you would ever encounter that velocity though sometimes it feels that way!
For you math fellows:
Saw this
