pglaves
#13338
Any suggestions for getting the sprocket bolt loose? In the head? I need to remove the head but that won't happen unless the sprocket bolt comes loose. Probably has never come off since it was built. I bought an Ingersol Rand impact wrench and no dice. I tried penetrating oil, heat till the oil started smoking and I can't get it to budge. HELP!
Lock the engine at TDC using the BMW mandrell or in its place a long arm 6mm allen wrench. Use a wire tie to fasten the chain and sprocket together to preserve valve timing.
Slowly take all slack out of the chain and then using a new, sharp, allen socket and a LONG lever apply pressure counterclockwise.
Be very careful. I know a couple of folks who broke cam chain guides banging on things here - which greatly increases the amount of work required.
