Most obsessive thing you've ever done to an airhead
gtgt_bangbang
I propose a sticky MOST OBSESSIVE REPAIR YOU'VE EVER DONE TO AN AIRHEAD
honorable mention submission:
Im putting a cush drive on a 78 along with the better, faster swing arm
I actually lapped the cush joint interface with valve grinding compound, to smooth out the fretting marks and increase the interface area.
not sure if I can tell the diff but MY CUSH IS GONNA BE TUSH !
There exist a socket that acts a good alignment mandrel ( must maintain proper relation/orientation / centering between the THRUST ADAPTER and the CLUTCH BELL HOUSING or dont bother doing this, plus you have to avoid getting any compound down inside on the D.shaft's wear faces ...
