Hi,
I'm new to MOA so thank you all in advance for your help. I have an 1983 R80RT. I bought it new over 30 years ago and all maintenance, other than the easy things, have been done by professionals. Now that I'm retired I'm having a little more fun doing more things myself. However, I went to do an "easy thing" and it's not working. The left rear blinker is behaving as if it has a burned out bulb. I have confirmed the problem is NOT the bulb. The connectors at the bulb all look good and clear. Where else should I be looking?
Possibly related to this, but not sure, is I've had intermittent ignition switch issues over the last year. I've cleaned all the connectors at the switch, as well, but the problem still exists. It's as if there's varying levels of power running through, or activated by, the switch. It's very inconsistent. Could these two be related or do I have two different problems going on?
Jeff
Jeff
