nevada72
Vintage User
Greetings all. My R100RT is coming along nicely. It is actually 100% rideable and enjoyable. There is just one thing - the left carb intermittently leaks (all over my boot!). I'll start the bike, let it warm up, head out - no leaks. But after awhile I'll smell gas, look down, and sure enough, it's leaking gas onto my boot. It does it for a few seconds and then stops. But farther down the road it will do it again. Maybe every 5-10 minutes.
I've replaced the float bowl gasket 3 times. I have somewhat adjusted the float level to see if that helps - it hasn't. I thought maybe the float was sticking so I played with that a little bit to see if that did anything - nope. I took the bowl off and tested the needle valve - it shuts off the gas when I lift the float and let's gas flow when I lower it. The carbs were recently rebuilt, but not, as it turns out, by someone who had a full knowledge of Bing carbs. He reversed my chock assemblies rendering the choke useless, which I discovered and fixed. That said, all the soft parts (float,diaphragm, gaskets, o-rings) and needle valve is new. I don't even know for sure where it's leaking from because it only happens when I'm riding. I'm assuming from the overflow, but I just don't know. The right carb is just fine - never leaks.
Any ideas?
Any ideas?
