widebmw
With both the stock floats and the dual floats the standard to start it to have the floats shut off the gas when the "Y" piece or the part that holds the float is parallel with the bottom of the body of the carb. Put a bowl under the carb and raise and lower the floats or the "Y" piece to shut the gas flow on and off.
To adjust the level bend the tab that hits the bottom of the float needle. It should shut off when the bar the floats hits is parallel to the bottom of the carb. I found that if I put a small wrench on its side up to the bottom of the carb where the float bowl sits it is easer to gauge when it is parallel.
Does any of this make sense ?
