Heated grip replacement
deilenberger
A bozo on the bus
Anyone done this on the older (gray - square) heated grips - if so - what did you use for replacement grips?
I tried generic - and the shoulder used to hold the heated grip on the left side creates a problem by moving the grip further away from the controls, which for short-thumb people (no comments please!) causes a problem.
I did check out the later model grips - and it looks like the grip would fit - but I'd need some sort of plastic endcap to cover where the wiring is on the early grip design.
Ideas?
jdiaz said:
Don, K1200RS/LT grips have a closed end.
Jon - cool. Now to see if replacements are available (did'ya know that replacements aren't available for the early heated grip kit.. bet you did) ;)
