deilenberger
A bozo on the bus
About the calipers- I thought that calipers where made to find center (within reason). I've always thought that both sides were independant of each other and hydrolically driven. They both come up to resistance from both sides and they self center???....or am I all wet on this?
You're correct, but only "within reason".. if a shop could take a very fine cut - a few thousands of an inch - (I have no idea how they'd do this since they would have to put the rim in a huge lathe) - then it probably wouldn't be an issue, but if the rotors wear enough and you had worn pads, and they took a bigger cut there is the possibility of pushing the outboard piston past it's normal travel design - which could result in failure.
If you can find a shop that thinks they could do this sort of job - please let us know who they are and what the results are.. I spent a lot of time trying to find a shop that would resurface a K75 rotor - and the only shop that tried it ruined the rotors to the point of making them unsafe.
