jconway607
JohnWC
I could use some advice. I am lubing the input shaft spline and rear wheel splines on my 83 R80. I bought a small tube of "BMW Microlube GL261" from the dealer to do this job. It says on it, "For use on clutch spline shaft". Then on the back of the package it claims you can use it for just about everything on the bike. It also mentions that it contains," mineral oil and lithium soap". It is a clear/yellow color. My questions are these.
All the articles I have read suggest a moly type grease, or mixing Honda Moly 60 with a Stuttgart grease, or some sticky blend. Moly grease seems to be popular for this job. All moly stuff I have used was grey. I can't believe this GL261 has any in it. And why mineral oil and "soap"? Has anyone actually used this stuff (GL261) or knows anything about it? Is it any good? Or should I go get some of the Honda stuff, or what? The splines are in good shape. I just want something that will last a while, and protect them.
Secondly, I find it a bit hard to believe that this GL261 can handle both the sliding/loading of the clutch shaft and the (I would imagine) much more demanding job of protecting the rear wheel splines. Can it do it? BMW, or at least Kluber Lubrication says so.
I'll use whatever does the best job. I just can't figure out what that is.
And I also can't say I have the greatest faith in the advice of some of the dealerships that don't even recognize as their own brand an airhead when it drives in. Thank you everyone for your help.
