RPGR90s
Member
I'm helping a buddy with a R60/5 where the clutch works but the engagement point doesn't happen until the lever is nearly all the way out.
I've checked cable and lever adjustments and they're perfect.
I had to remove the rear end to address some leaking seals so decided to tear into a visual inspection of the clutch.
Clutch Spring height is .6940", which appears within spec.
Friction disc thickness is .2345" which is within spec.
However, this clutch has six .154" (4mm) thickness spacers installed between the pressure ring and pressure plate. (BMW p/n 21 21 0 070 511).
I'm curious why they're used (I've never seen them on R90s's, R90/6's or R75/5's I've worked on)?
And.....would their use would be causing the late engagement of the clutch?
Thanks much,
RPGR90s
Thanks much,
RPGR90s
