Today after a long ride I pulled my 2005 r 1200 RT into the garage to park it and while trying to miss my wife's Can-Am Spyder I dropped the bike on its right side. While immediately pulling the top and side cases off to lift the bike up I noticed brake fluid on the ground under the area of the bike where the rear brake fluid reservoir is located. After the bike was on its center stand I estimated maybe a quarter to a half of a cup of fluid was on the concrete. I felt the fluid and smelled it-it was brake fluid. No damage to the bike.
Thinking that I might be able to just add fluid to the reservoir I checked the rear brake fluid container and it was full. So I turned on the ignition and pressed both front and rear brakes and the level stated the same-full, and no brake system warnings appeared. For the heck of it I checked the front brake reservoir and it was full. The brake pressure modulator is a sealed system and I don't think it would leak from this event. I have not yet tried to ride the bike, a little nervous about doing so until I have an answer to the leak source.
Where did the fluid come from?
