gtgt_bangbang
was driving me crazy (true, not a long trip ) to get those tiny orings on the Idle Mixture screw 13 11 1 335 302
Kind of hard to believe the parts fiche have it right ,
max calls for a 3,2X1,8 for both
Idle Jet ( easy fit) and the Mix screw (got to be kiddin... fillister head on one side and sharp threads from the other direction, both sides are ~7mm OD.
I deburred and chamfered the edges of screw head to try to slip the ring over , but no love,
and definately easy to scratch the oring on the screw driver slot, even cleaned & smoothed.
Recommed working on a clean white floor after playing " Find The Oring" acouple times trying to make it right.
No advantage to starting from thread end except harder to lose the ring
So I ended up rolling the O-ring onto a 1/8 pin punch, let it ( and me ) relax little while,
Rolled the oring from the pin punch to a hollow hole punch ( 5/16 was really too large but closest I had that fit over the screw head,
there are probably better tube sizes available for the 2nd transfer if you are the Plan Ahead type )
then rolled the oring off the hole punch onto the Idle Mix Screw ,
easy breazy.
Hard to believe the oring stretched that far , but these are fresh and a loupe inspection doesn't show any slices or scars.
easy breazy.
