b25bsaboy
The frame for the 1976 R75/6 is ready for the next process of plastic bead blasting, some re-welding of cracked gussets and powder coating/painting?
I want to remove the bearing races in the head stead, but the angle is as such you canÔÇÖt get a brass drift from the opposite side to knock them out. Is there a simple way of doing this without making a mess?
The lower bearing is also stuck onto the shaft that goes up through the head steady that is the bottom bearing. It appears it has not seen any new grease since coming off the assembly line and it appears to be frozen in place. Any ideas to removing this from the shaft as well.
Up date:
I also just cleaned up my spelling errors. My apologies..
Up date:
