I used to buy stretchy rubber straps to hold down my battery. There perpendicular metal rods on each end.
Any ideas for a source?
Campbell Tellman II
'93 R100RT
Campbell Tellman II
'93 R100RT
I have the hold down you mention. They are not very good. Campbell Tellman II
'93 R100RT
I have the hold down you mention. They are not very good. I have to reattach the hold downs once a week. I have had past airheads with the stretchy straps and they worked very well. I checked several websites including Max and Bob's and found the strap with a number on the fiche but didn't see a price so I assume there are none available. I can engineer something using the existing battery box.
Thanks for the input.
Campbell Tellman II
'93 R100RT
That stretchy strap from the R80 will not work?
Just for the record - I wasn't suggesting the straps for my '86 R80 would fit the subject bike.
Just using my machine for a reference to check the fiche.........
Geez...havnt you guys ever heard of bailing wire?
Daym Jimmie, we need to team up!
I hadn't even thought of the seat warmer idea.
On a serious note, if the strap is a little loose, some innertube folded underneath might tighten it up just enough.
Ken
I agree with you, Campbell! I have a Westco in my 1978 R100S and the stock battery hold down will not work. The "spokes" are not long enough for the threaded ends to reach through the bridge to attach the nuts.
