All: I am thinking of undertaking a retrofit attempt with the F800ST my wife bought earlier in the year. Anyone ever tried this? Any tips or lessons learned?
You'll need the dealer to reprogram the computer to use the TPMS. When I had my F800S, my TPMS had to be replaced, and it did not work until I took it back and they reprogrammed the computer. I had to wait until they got the disk in, as well.
I seriously considered doing a retrofit also... but the master mechanic at my local dealership did not express a lot of confidence in being able to add the option to the bike and get it to be "accepted" by the system.
He also noted that the batteries in the sensors are NOT replaceable and when they die (after 3 - 5 years he said) the sensor needed to be replaced for a cost of $180 + labor which would not be cheap since you have to dismount/remount the tire and reprogram the system...
At that point I started looking at the keyfob type sensor systems...
After I picked up two nails in on two different rear tires within a 3 month time frame I decided it was time to check into a TPM system. I purchased the TireGard system about a month ago and I am satisfied with the purchase. It is easy to set up and I have found the tire pressure read outs to be fairly accurate. It may not be as good as the factory installed system but I do have some peace of mind riding down the road and being able to know if I have a tire going down.
