Headlight Adjustment:
13mm, clockwise turns adjust beam higher (clockwise=up counterclockwise=down)
The lever is at about 2 o'clock from the left side low beam. It surrounds the fine tuning adjustment for up and down (the left-right adjustment is at about 7 o'clock on the right low beam). When down (90 degrees), it's flush with the bulb access bezel (for 1-up riding). When up, in-line with the headlight axis, it surrounds the adjustment nut (for 2-up riding).
Images are also included in the online Rider's Manual.
What I am really looking for is an earlier posters instructions at the aiming process. He had the bike so many feet away from a wall with the wall marked at a certain height then adusted the light to fall at the mark on the wall. I know how to adjust the light itself, just want to aim it at the correct height.
Here is the official way to do adjust the headlight:
On your flat floored garage, make a mark on the floor, 16 feet 5 inches from a wall (officially 5 meters).
While sitting on your bike, with a normal load, that means balancing and having your big feet on the
pegs!...have someone measure the distance from the CENTER of the headlight to the garage floor.
Put a mark at this same vertical distance on the wall, and another mark 2 inches below it (5 cm).
Move your bike, that means don't put it on the centerstand, until the FRONT AXLE is above the 16'5"
floor mark. Aim the headlight for the two marks, with your normal weight and load as before. The
bucket should be adjusted for the cutoff to dark area on top to lighted area, to be between the two
marks.
