I have a problem that comes and goes, bike will run for a while, then run on 1 cylinder is seems like, and than stop.
During the winter a got the bike dual-plugged, and also fitted a SilentHektik ignition system.
I adjusted the ignition and testdrove a week ago, bike seemed to run better than ever. Next morning drove off for work, bike stopped after 5 min drive. I suspected the rotor bolt, where the ignition signal is picked up, to have gotton loose. It sure didn??t take much force to unscrew it. So new adjustment, and bolt fastened with correct force, 25nm.
Today I was gonna test again, it ran 200 meters. Hmm. I hr later I??m gonna chech the ignition with a lamp. It??s right on the mark. So I dress up, planning to go for 2-3 hrs. After 7-8 min., the problems are back. Loosing power, seems like I run one 1 cyl. Turns around trying to make it home. Stops on the side of the road. Right float chamber is dry, seems to be lower than usual in the left one too. With ignition on, not a drop of fuel flowing into the chamber.
I friend picks me up. I??m starting to suspect the fuel shed system;
http://www.realoem.com/bmw/showparts.do?model=0469&mospid=51666&btnr=16_0241&hg=16&fg=13
Back home, ignition on, fuel flows again.
On a bike without this system, european, and older american, does the fuel line run directly from the petcock to the carburator? Or are the sides connected?
I understand it??s not uncommon to remove the system. Anybody else experienced problems with the ?¿shed?¿ system?
There are 2 valves in the ?¿shed?¿. Are the output lines connected? If so, if 1 valve failed, I should have gotton half of normal fuel flow?
Hans
Norway
Hans
Norway
