tibork
One other condition with the 94 model year is that the sidestand must be up for the bike to start/run. Later years that changed allowing them to start and run as long as it was in neutral and some owners (myself included) rewired the early models to function that way.
Correct mcmx, however even with the side stand down you should still get the neutral light. Side stand only prevents from starting with a separate switch but not from getting the neutral light. How did you rewire it? I also liked that on my Yamaha, I could start it with the side stand down as long as it was in neutral.
So today I got home OK from the dog sitting, the light came on in the morning soon as I turned the ignition on, however on the way home at some of the red light I didn't get the neutral light even when standing for a couple of minutes - no problem, bike still ran. I got home, then a short while later had to run to a store, again light didn't come on right away but wasn't bad, however trying to leave from the store I had to sit, play with the shifter, rock the bike and wait two minutes again - bit annoying. Then tonight I ran another short test ride and again it was just fine. So I guess it's just how it feels at the time ..
I guess first priority is to get the clutch switch fixed and also pull the sensor and as some of you mentioned replace the seal.
Thank you for all the comments and suggestions!
