I will start by apologizing to you all if this is something I should know about and/or has been answered many times before. I am experiencing an intermittent issue starting my 2009 R1200GS when the engine (and the weather is really hot). The BMW dealer recently installed a brand new BMW battery (read expensive) to replace the original one which I thought was getting a bit weak. The bike has now 65,000 km or 40,000 miles. the dealer and I have checked at various occasions that the voltage at the battery is as it should with the key off, key on and also with the bike running so it appears that everything is OK with the battery and the charging system. When cold, the bike starts normally with the starter turning the engine over as you would expect. When the engine is hot, say after stopping for taking on fuel, the starter sounds like it will not be successful turning the engine over at all for say 0.5 to 1 second and then it does turn the engine over and the bike starts. Anyone hearing this, believes that they are about to witness a bike with a dead or weak battery. Yes I am running a set of PIAA's that are activated by the ignition but I make a point of turning them off before I kill the engine and the lazy starter syndrome appears to be independent of the driving lights being ON or OFF. I am curious to know if this is something common with the oilheads and if it is the sign that something more serious will eventually cause me to be stranded somewhere.
Thank you,
Dominique Rambie
Mississauga, ON
Thank you,
Dominique Rambie
Mississauga, ON
