senseamidmadness
Neglected Bike Adopter
The latest in the saga of the Saddest R850R You Ever Did See. Yet more disappointment!
A couple of days ago I put in the third replacement fuel pump I've had in this bike, after the quick-fix used OEM one I had started doing its best impression of a table saw cutting wood. This new pump is a Quantum. I replaced the fuel filter with a proper Mahle one just in case and put a new intake screen in, which is a very good design and shouldn't let any gunk into the pump from the filthy fuel tank this bike has. (A replacement fuel tank is planned in the future but man are they expensive and hard to find for this bike.)
I had left the battery on a 2-amp smart charger for about a day just two days prior to this. It's a Bikemaster AGM Platinum battery. I purchased one new in March and had it replaced under warranty; the current battery in the bike is the one I received as a warranty replacement. It was brand new in May.
Immediately after, I tried to start the bike, and it wouldn't run. I could hear the fuel pump priming just fine, and for the first few tries the engine did crank, but it sounded slower than I thought it would be. I thought the battery would be fully charged so this didn't seem right.
Tried to crank it a few times, with no start, and it got slower and slower. Eventually it just wouldn't turn at all -- the fuel pump primes, the starter solenoid clicks and the headlight turns off and the gauge cluster lights go dim when I hit the starter button, but the engine doesn't move.
Left it on the charger again for a full day. Checked it out briefly yesterday. The charger said "battery is fully charged" but got the exact same result when I hit the starter button -- click, no crank.
Is it a busted battery? Should I cut my losses and just buy a proper Motobatt without trying to get a warranty replacement? Should I be concerned about the starter?
