A lot of the time the year helps on a question like this along with the specific switch in question (left or right).
has anyone had there handle bar switches replaced under recall on r1200rt
I'm assuming you're referring to the "campaign" Bmw is having to replace the left and right switch clusters with new/updated ones.
if that is true, then yes, I have had that done on my 2013 BMW R1200RT.?
Is this only on the R1200RT? BMW has had a lot of bad switches on other models.
edit: dont know if it would affect other models like the k1300's; do they use the same switch part numbers as the RT's?
It is a "Campaign" according to my dealer.
