Results 1 to 9 of 9
Thread: 2012 R1200GS Rally - Wind Screen Replacement
    Jul 2006
    Bath, Mi
    Need some advice, the OEM, and the OEM taller version windscreens aren't doing the trick for me. I'm experiencing considerable wind noise, and buffeting. I prefer to look over the shield versus through it, I'm 5'10, 31" inseam. Can anyone provide me with a recommendation on a very good quality replacement windshield. Note: I'm not interested in lower protection.
    thanks in advance.
    73516 Michigan
    Registered User brianm's Avatar
    Aug 2008
    San Juan Capistrano, CA
    I had similar issue with my '12 GS. Tried all positions forward and back but still had uncomfortable buffeting at higher speed. (65+ or strong headwinds)
    Talked with some other riders and searched around, then decided to put on the Givi 330DT. Worked much better, but not as good as I had hoped. The trick I found was to also install the GSA Winglets. Worked like magic.
    Good luck.
    '05 R1200RT
    12' R1200GS
    '08 DRZ400s
    Previous: Honda ST1300, Ducati ST3S, Triumph T100, and many others...
    na1g
    May 2011
    Have a look at the Laminar Lip: www.laminarlip.com
    I don't know anything about the Lip for your GS but I've had good results with the Lips I had on my ST1300 and FJR. Much better price than a new windscreen, too.
    pete
    I was in a similar situation with my RT ? enough protection, but buffeting. The Wunderlich Vario windshield attachment worked for me, smoothing out the airflow on the top. I imagine the Laminar Lip does the same, but the Vario is adjustable.
    Quote Originally Posted by 73516 View Post
    thanks in advance.
    73516 Michigan
    There are lots of factors. Even the type of helmet you wear makes a difference. I had a 2011 GS and had an RT before that. On the GS, I tried the Givi and the full Aeroflow. No matter which windscreen you pick, you'll probably never get dead air like you can on an RT. After the windscreen, there are also things like the SAENG deflectors. It can be an expensive trial and error process. You're best bet is to see if you can trade rides with other GS riders to see what other folks have and if it will work for you.
    John
    May 2011
    Aptos, Calif.
    I have a 2011GS. Just like you, had the same buffeting problem. Changed helmets, tried the Lip, still a lot of buffeting. Went with the Aeroflow Sport wind shield and took care of the problem for me. I am 5-11 and I think ordered a tall. I can't tell you why, but the bike even handled better in a cross wind with the Aeroflow shield. I have no experience with an RT but my guess is it is not as quiet.
    2 years ago I did a search and found quite a bit of information on the forum about GS wind shields. This helped steer me in the direction I took.
    Good luck to you on your search.
    John
    Registered User MWS's Avatar
    Orange Village, Ohio
    http://www.wunderlichamerica.com/mot...10024-025.html
    Solved that problem for me. I'm also 5'11"
    Mark
    Registered User PeoriaMac's Avatar
    Aug 2003
    Washington, Illinois
    A Cee Bailey worked for my 2005 GS. With the seat on the low setting...it's almost too tall. Good wind protection however.
    Mac
    1986 R80RT, 2005 R1200GS
    Livin' Large On The Lake
    Registered User Moto316's Avatar
    Nov 2007
    Phoenix, AZ
    I have a 2007 GS and switched to an Aeroflow last year. A terrific improvement, very quiet and no buffeting. I like the quality of construction and the GSA style cross brace, this helps the windshield hold its shape. I had a Cee Bailey for a few years and that did not work at all. At highway speeds the windshield flexed downward and increased the amount of turbulence in the cockpit.
