SPIKESBIKE
Does any one use Dyna Beads on their Oilheads? If so any thoughts?
Never had a problem with beads in valves.
They can also get stuck in your valve stem when you check your air pressure.
dyna beads = snake oil foolishness. IMHO
I am getting over 12,000 miles on my front and could get more on my rear if I didn't change at the same time.
I suspect folks are trying to find a cheap easy carefree way to balance tires since the beads came along.
Some very experienced mechanics and riders even question the need to balance motorcycle tires. I do and I use steel weights. Lead weights are illegal in some states so that is becoming a non-issue.
