This winter I rebuilt my carbs on my 92 RT. Cleaned carbs. Made sure the jets were clear. Installed new O rings,5 of them in each carb. New floats the ones that ride up on posts, of course it has new bowls. New diaphrams and gaskets. Marked the throttle and choke cable adjusters and returned them to the previous positions. Just started the bike, of course it started out with empty bowls. Flicked on choke, hit the starter and the thing fired right up.Took bike around block and it ran ok. Got back to house pulled in the clutch, let off the gas and it stalled. Started it back up revved it a couple of times , returned throttle to idle and it stalled. Just will not idle. If I gas it it runs good. Thought it maybe was flooding, pulled bowls and bent the tabs that the floats push on to control the amount of gas, still no idle. Pulled carbs and went back over instructions and checked things out and still no idle. I then restarted bike with the bowls being empty again. idled great with choke on , it started to die I gave it some throttle and turned off the choke and it purred along, again backed off the gas and it stalled again, no idle. Checked to make sure the little screws that you put into one of the holes in the corner of the bowls were there and they are. Instructions said without them the bike wouldn't idle. What should I do next??? Should I play with the throttle cable adjusters on the carbs???
