Wierd ABS fault
spikethebike
I have been getting ABS faults when I hit bumps with my K12RS.
When I stop and switch the ignition off then on again, it clears.
This caused me a bit of excitment at one point today as I got a little air at the same time I needed to scrub off a bit of speed- the front locked and started to go sideways, butt I caught it before it got too interesting.
Could this be caused by the sensor gap being a bit off?
Thanks a lot for any suggestions!
Spike
I'd try that, Spike, but I'd look and make sure the sensor is mounted securely too.
Righto, I'll check everything in the general area. I know this is not supposed to happen as I have hammered my previous K12 over Mattole road at injudicious speeds without a problem!
