Gas cans mounted in from of Pannier
RogerA
Continually Confused
Hi:
I am planning on mounting gas cans in front of the BMW panniers on my R1200GSA, similar to the picture shown (different brand of panniers of course).
Are there any kits available? Anyone have experience with doing this?
Advice would be appreciated.
Roger
I mounted a few MSR fuel bottles on my TT boxes and find it works fine. How much extra fuel do you really need with an Adv anyway???:scratch the 3 quarts or so I carry were enough to get me out of a bind in the Yukon this summer, but encountering an entire town being out of gas doesn't happen often either...:whistle
Kolpin makes fuel tanks that should fit on your bike too.
This is the setup I used for the last Prudhoe bay trip:
Most of the gas if for for my wife's R1200GS, plus a couple of gallons for me.
This setup is top heavy, especially when I am carry four tires as well (you guessed it, 2 for me and two for Kathy) so anything I can do to lower the CG will help.
Roger
Boy, I'd like to see that. I've been experimenting with some large hose clamps to mount MSR bottles on my saddlebags (like a fire extinguisher). I've almost got it, but I'm reluctant to drill the necessary holes in my bags....
Interesting stuff. Did you read how he made a deal with his friend to buy gas from his friends 11 gallon tank and post dated the check so he could stop payment on it? Not someone I would like to know.
I mounted a few MSR fuel bottles...
That's what I do. The seal on these screw-top fuel bottles is about as secure as one can get, and the opening accepts a standard fuel nozzle (watch out for blow-back). I carry one in a case on longer trips.
Fred
Neat setup I saw at Hunter Mountain during Color in the Catskills
Boy, that's a lot of weight up high. The Peg-Packers mentioned in thtduck's post, in this thread, at least carry the fuel much lower. That has got to make a difference when it comes to handling.
only probelm with this set up is the wieght of the fuel is very high up...
maike sure that you try and mount what ever system for extra tanks as low as possible in the the "weight Triangle" on the cycle... the cycle will handle much better that way when you get into or on to bad ans slimy roads..
Those Peg Packers setups look really well thought out for large amounts of fuel carried low. Definitely brings the weight to the COG.
I have some Touratech holders for the larger MSR bottles and mounted them in front of the TT cases. they come with nylon straps,but I added a ziptie to prevent easy walk-offs. I use them when crossing West Texas,not so much for me but for my riding partners R bike that "almost" makes the next station when they are 250 miles apart
saw this set up on ADV rider...not mine...I mounted two in front
Looks like 4 nice red bombs just waiting for somebody to rear end the bike. I would not want to be on that thing when it happens.
Wouldn't it be easier to install a bigger gas tank like we did on our old Airheads? Oh yeah, your newer bikes don't have the gas tank in the normal place. Hmm, there must be a way.
Drill the holes. :D I did.
<img src="http://www.snafu.org/pics/r1200gs/2007/0823-msrgas/p-20070823-1445-3131.jpg" title="holes for gas mounts">
More at http://www.snafu.org/pics/r1200gs/2007/0823-msrgas/
Uh, you've got fuel, but no air or ignition source, thus no bomb. The bottles don't shatter. If you are in a rear ender the bottles are likely to have the least amount of damage. They are stronger than your gas tank.
Or do you also have problems riding around with 5-10 gallons of gas in a plastic tank between your legs in case you're T-boned?
They may pick up a stone in front.
Those MSR bottles are thin walled aluminum.
I thought about that, my legs and that big Adventure tank block them most of the time , mounting on the rear also brings concerns. I used those bottles camping years ago and really abused them at times with no issues. More worried about a big boulder than a stone hit:jawdrop
I'd also trust these more than a plastic jug as mentioned. I've melted the side reflectors off my license frame running across west Texas with the heat tunnel created by the TT cases.
