westhautianplen
The Bike: 2007 R1200RT 21K miles. Has had brake line and cable recall performed.
I am a little on the nauseated side as I write. I rode over to the in-laws yesterday evening and on the way the Brake Failure light blinked and then stayed on. Paranoia set in immediately, tried both the front and rear brakes independently and both worked but the rear seamed to require a little more pressure. I tested the brakes several times hoping it would reset or clear. On the way back home I realized that the ABS was not working, because I could lock up both the front and rear tires. After I arrived home I checked the front Brake fluid level via the sight glass and it was filled to the tip of the glass. I check the rear brake level and it was at the top. I check the brake lights and both lamps were working. I checked the cables from the rear Final drive and from the front sender unit and both appear to be without any physical damage. I started the bike and as it idled the brake failure light blinked like normal so I proceeded out of the drive the blinking brake failure light went out until I applied enough pressure to lock the rear tire and then the dreaded brake failure light came on and stayed on again. I have turned the key of and restarted the bike, however the failure light stays on. I disconnected the battery in an attempt to wipe the fault, but the light stayed on.
Now for the $3500.00 question of the day. Is there anything else I can check prior to scheduling a service?
