jnrugg
I bought the HID kit for my 02 RT from 1Off Motorsports just before they closed shop.
So I can't go to them for help.
Wired up ok and when it turns on it is great, even in the daylight.
The issue is the light does not always come on when I turn on the ignition.
If I turn it on and off several times it will come one but I don't want to wear out the ignition switch.
I have it wired in as they say, but is there a better way or is this a problem with the ballast or the unit? If so then I will just go back to the regular bulb, if not then I would like to fix it.
Thanks,
Thanks,
