F
FatChance
I have a '00 1150GS with 49K miles that has been a great bike since I got it in 2004 with 5900 miles. I do regular service on it, including changing the transmission oil (80-90 synthetic) and the final drive (80-90 dino) with every oil/filter change. There have been no bad symptoms other than some recent oil seepage and a little play in the FD consistent with worn pivot bearings. I mostly use the GS for multi-day to multi-week rides through the Rockies (FatWife has her own '01 1150GS). I'm old and ride it fast, but nothing rough at all. I've got a DR650 for off road riding.
Since winter is here, I decided to do a full, in-depth maintenance because I plan on keeping this bike forever. I planned on fixing the oil seep, lube the clutch splines, service the swing arm bearings, put in some Rubber Chicken pivot bushings and renew the FD bearings and seal over the winter. Normal 50K mile stuff. In the last 1000-1500 miles, the oil seepage has gotten worse, but it is nothing I would call a leak (no drips). I figured the transmission input shaft and FD seals were shot. The clutch has been working normally. Here is the seepage on the right bottom of the engine:
Here is the FD showing a seeping seal. The FD lube always comes out clean and there is no play with the rear brake activated, so my plan is to just go ahead and replace the bearings and seal, maybe check the pinion seal. I'll also put in some Rubber Chicken Racing pivot bushings to replace the worn pivot bearings. It certainly is time to do this service.
With the starter removed, I could confirm that the clutch and rear of the engine were dry, so the engine rear main seal was fine and the problem was the transmission input shaft seal. Just as suspected and an easy fix.
The transmission input shaft seal is obviously shot:
Now for the BAD news. The input shaft spines are in bad shape:
The clutch disk splines are even worse!
Looks like Basin Motorcycle Works will be making some big bucks rebuilding my transmission (i.e. new input shaft and seals)! If only a leaking transmission seal could have kept the input splines lubed! Over many decades, I've always had the best seal performance using dino oil instead of synthetic. I wonder if using synthetic in the transmission might have been a contributing factor in the seal failure? I may never know, but I'm considering going back to dino.
I reckon those clutch splines only had another thousand miles or so before a total failure. So, I guess clean living and pure thoughts kept me lucky enough that the FD or the clutch didn't totally fail while off in some far distant place. At least the bike is safe on the lift in my shop with the first snow of November on the ground...
Still, not what I wanted to find. It is going to be a long, cold, expensive winter.
