This is the second valve job i've had done in the 29,000 miles that i've owned it.
But, this is the second valve job (adjustment) in the past 9,000 miles!!!!
But that was because BOTH of them were done improperly.
Checking every 15-20K should be good enough IF they are done to the specs that I suggested each time.
If you set the exhausts on the tight side, you'll probably end up having problems well before that. That's what Bob's did the FIRST time.
The higher the milage, the more often you want to check them because, once exhaust valve recession starts, it's rate increases.
