wooden front brakes 87 k75
48882
I recently had a low speed fall to the right side. The brake lever took a beating, but I was able to straighten it with the help of a friend.
However, now the front brake response is 'wooden' as in the there doesn't seem to be any
bite in the brake pads. The bike stops, but it seems like its a longer stopping distance. Could my fall have damaged the brake pads in some way?
WAG: the fall damaged the piston inside the master cylinder.
Also examine the brake lines; the "hard" lines might've gotten a kink.
The lever has been 'unbent' and look approximately as good as new, and the brake lines look to be in the right place.
So I guess that means examine the master cylinder, which I'll put next on my list of 'to do'
thanks!
Also examine the pivot pin, and the interface between the lever and the outer end of the piston: if there is no clearance, or if it got mashed, that would also affect the operation and feel.
Sorry, I thought I had closed the loop on this. I took the lever apart, and where the lever interfaces with the master cylinder, there was a lot of 'goop'. I cleaned off the stuff and the lever action has been fine, since.
Ah, goop... similar to tarpiculates and crapitation, but sometimes easier to deal with. 🤪
