What relay to change turn indicator bulbs to LED? 1986 R80RT
Changed my turn single bulbs to LED bulbs and got the dreaded hyper flash.
I am an electrical noob and I don’t know the three prong relay with resistance I need so the LED bulbs work and I don’t get hyper flash.
I contacted Euro motorsports and they say they don’t stock one for my year of bike
Can anyone advise me what I need?
Thanks very much.
Kat's website says that LED turn signals will NOT work on an '81 to '95 model year, even with a different flasher module.
Alternative: you can add an extra resistor in parallel (one per side, NOT one per LED, unless space is an issue and you need the smaller size of a lower-wattage resistor) to pull the extra current needed for the flasher.
So, you do NOT save power, you just get the longer life and instant on-off of the LEDs.
FWIW I don't think the instant on/off property of LEDs is desirable for signal lights. It's harder to notice the change when it's so fast.
Anton- Concur 100%. I recently fitted LED signal lamps and then almost immediately went back to standards after numerous "constructive" comments from my riding partners.
