superblackbird
I'm experiencing some weird things with my K16 15 with 600km on it. Can somebody can confirm that they are normal or not...
First one: When braking with pressure on both front lever an rear brake pedal, when almost stopped i'm feeling some pulse on the rear brake pedals like if ABS was engaging and also pedals at one point is going down while the front brake caliper is activated (rear pedal going back up after) meaning that i'm finishing with a rude stopping because of the suddenly activated front calipers linked pistons.
Second one: I'm also feeling vibration when cluth released on neutral and clutch is noisier than when lever is pulled loud enough to be noticeable. Also i'm felling a ''pulse'' in the clutch lever when pulled and decelerating with a speed engaged and off throttle.
If someone can tell me if I have to worried or not it will be very appreciated
Thank you in advance for your help...
