Hello friends
I think that some of this trouble with valve stems is man made due to some of the cleaning products we use today on our tires and wheels.
Just a thought
Take care my friends
In my case, the adherence of the rubber plug to the brass tube failed allowing air to leak out around the stem. When the SECOND one failed (high in the Rockies of Colorado) is was able to place a couple of small zip-ties around the plug, snug them up real good, inflate the tire to a safe ~ 30 psi and limp back into Gunnison (around 40 miles, as I recall). The tire seemed to lose no significant amount of air using that method. Ergo, zip-ties are ALWAYS in my emergency bag!
Hello friends
Just a thought
Nope you can't push it in from the outside. You have to break one of the beads on the tire & put it in from the inside.
I installed the valve from the outside, patiently working in the valve with a couple of screwdrivers andwith a little oil for lubricant.
Bike: '02 1150GS
Be aware that using oil as lubricant on rubber can cause premature deterioration of the rubber.Soap or saliva are much better alteratives.
Here is some better info on what looks to be the same product from the kurvygirl site. I'm not sure if you can order from this company anymore, as the owner died in a MC accident awhile back, but the website is still up. Hope this helps.
http://www.motorcycleanchor.com/tire_valves/index.htm
This link takes you to the order page however I checked the Home page and found this so it looks like for now these valves are not available:
NOTICE:
Due the tragic and untimely passing of Marc Glasgow
(aka. the Cyberpoet), the owner and operator of this web-based business, orders in process may be delayed while we determine stock levels and a variety of other matters. New orders will not be accepted until further notice.
Please check back here for further updates
but i went ahead and ordered a set from The Mrs, and got them about a month ago.
I ordered a set a couple of days ago from the web page and have recieved a shipping confirmation. Should be here in a day or two.
