kbocchicchio
I have a 1995 R100R Mystic that I bought a few months ago (my first airhead so I am a rookie) with only 1000 miles on it. After cleanup of all issues with 15 year old gas, I when for a ride and found the clutch slipping in 4th and 5th gear. Suspected that the spline lube may have dried out or the clutch control piston was sticking. Decided to lube the spline. I separated the case and cleaned the spline with some carb cleaner. After I blew it dry, I noticed some pieces of an orange in color deteriorated seal of some type ended up in my catch pan (see attached picture). I had not yet disassembled the clutch control assembly other than to remove the clutch arm to allow the transmission to move back. I checked every article and schematic I could find and cannot locate the part or where it came from. Any help would be greatly appreciated.
