not exactly. the worst that can happen would be that it overpressurizes, and blows a rear main seal. not likely, but it is possible. and just becaue a dealer's tech is not careful, and overfills your bike, does not make it an okay practice. these bikes really like their oil level to be around center of the window on a refill. more than that & they just end to burn it off more quickly intil they get to the desired level.The worst that can happen is that the extra oil will end up in the airbox. I wouldn't worry about having an 1/8 of a quart too much. That is just an 1/8 you won't have to add in the next 1,000 miles. I have even had mine come back from a dealer with the sight glass completely filled when the bike is on the center stand.
THANKS GENTS!
I think I will drain some oil. Don't like the idea of foam in the crank-case. Before I do that I want to do the 'tilt test' suggested by ChrisF. This will at least give me an idea of where I am to start. Let me add that I was (I thought), very careful filling it after the drain and filter but it seems to require a bit more gentleness than I anticipated. Any thoughts about re-using the crush washer one time? Also, I'm not crazy about the method of inserting a flexibe tube through the fill hole. It might get snagged and retained and then what am I looking at? Splitting the case to retrieve foreign bodies?.....Expensive.
Phenomenal response/good insight
My sincere gratitude!
Ed
Because oil sometimes hides in the oilhead engines, it's a good idea not to start with four quarts. I fill with 3.5 quarts and then go for a ride. Then I park it on the side stand for ten minutes or so and then put it on the center stand. After it settles, I top up a bit. Even then I don't go above the dot. That allows for hidden oil to appear later.
I suppose then in good faith and whatnot I'll drain a bit out of the bottom before riding season starts again. It's going to get another oil change very soon because my oil was very very dirty- a SUV backed over the bike while parked on the street, actually had th nerve to pick it up before driving away. Cracked the valve cover, I had to ride 40 miles home in the rain stopping every 10 to top up the oil.
It was a great day.
It then got parked for a new valve cover, and being winter (late november) never got taken out again. Now I just need a new headlight, new mirror, new instrument cluster assembly, new clutch lever, etc. Winter projects.
