hi, I want to replace the throttle shaft o ring but don't want to remove the butterfly is there a way to this? Thanks the carbs are CV Bings regards dave
The photos of the right way and wrong way of installing the the butterflies were taken from my website,
http://bmwmotorcycletech.info/bingcv.htm
snowbum
Right on SIR.......... This is why many folks who can, and/or have the knowledge to produce information in a media format do NOT........ Folks have no idea what copyright means and do all that they can to violate it...........THANKS FOR WHAT YOU HAVE PRODUCED for us............. God bless.......DennisThe photos of the right way and wrong way of installing the the butterflies were taken from my website,
snowbum
Brook has a good write up with photos. The one thing that I would add is with regards to aligning the butterfly plate. I start assembly with the throttle shaft, but probably doesn't matter the order. I find it easier to do with the least amount of parts attached. With the butterfly installed and the screws lightly snug, rotate the throttle to the fully close position. While holding the throttle shaft in its closed position, you can adjust the butterfly so there is minimal light protruding around the plate. I usually check the adjustment by holding it up to the sky, but any bright light source would work. When adjusted properly, keep holding the throttle shaft in the closed position and tighten the screws. Once adjusted and both screws are tightened, test the movement again, then remove one screw at a time and apply loctite. If you ask the question, you'll get plenty of responses, but I use blue loctite. I asked around and the greater consensus was that blue was more than sufficient and would not require heat to remove screws in the future. Of course, you could peen the screws again if you prefer. It sounds harder than it actually is. Another trick to help you, it the plate usually has marks on it were the throttle shaft was. Looking at Brook's photo below, you can see the former outline just above the throttle shaft on the left and just below the throttle shaft to the right indicating that the butterfly plate is rotated a few degrees clockwise from its original position. The closer you can get the butterfly plate to its original position, the better, IMO. Brooks, I hope you don't mind me linking a photo to this post. If you do let me know and I will remove the link.
