I had to remove the rear cover of my r75/5 transmission in order to retighten one of the shift fork pivot bolts. I cleaned the two surfaces and used a new gasket but upon reassembly and installation it now leaks at the gasket. The cover and transmission gasket surfaces looked good but the last person who worked on it had used a gasket sealant on the gasket when reassembled. I hate to use it but I dislike oil leaks more so I'm going to take it out and redo it with gasket sealant. Any recommendation for this type of application. Thanks
