Forgive me Father Beemer for I have sinned…
I should have know better, but I did it anyway. Finally started working on the ‘80 R65 that I purchased a while back. The bike sat in a garage for over 20 years after the owner passed away.
After stripping sheet metal off, I hooked up the new battery I had purchased to check the electrical system. Sure enough, the panel lit up as it should. Briefly pressing the starter button with plugs out confirmed power to the starter.
Then I failed.
Something caught my eye with the rear coil, and I started fidgeting with it. Convinced there was an issue with a connection, I loosened the mounting bracket of the coil until the coil fell out. Of course it touched a number of other electrical connections as it fell..
It was at this moment I realized I had accidentally left the battery connected and the main key switch in the “on” position..
Yep, everything dead.
There was no noise, no smoke, no indication of electrical failure. But dash light, etc., all dead.
Over the years of messing with my ‘70s Honda’s, it’s usually a matter of swapping out the main fuse near the battery when such nonsense occurs. No such luck on an airhead.
I have a large schematic of the electrical system, along with a big fat Clymer’s manual as resources. Yet nothing to guide me on correcting this fatal error.
Before I begin poking wires in search of Direct Current and making a bigger mess, I would appreciate suggestions on how to begin navigation of a repair in a proper progressive manor.
Thanks to all with suggestions on a process, as I beg for absolution. I truly should have known better to mess with anything electric with the batter still connected.
Then I failed.
