R60/6 rear wheel
bikebombs
Member
I have replaced the rear tire on my 1976 r60/6. Am I correct only cleaning but not greasing the left inner wheel splines/gears.
I personally would re-lubricate the clean splines with a moly grease with at least 25% moly content by volume.
Hi again. I have gone to two cities and 6 auto stores re: moly grease. Nobody has ever even heard of 25% moly grease. 5% is the norm even at garages. Can I use moly grease gun lube?
Check out section 6A on this page:
https://bmwmotorcycletech.info/chemicalsetc.htm
Check motorcycle shops. Honda and Yamaha have their own greases. Honda used to offer Honda Moly 60 but that went away a number of years ago. I believe, as Snowbum says, that was replaced by Honda Moly 77. Not quite as good but suitable.
That is the issue. That 5% stuff is moly in name only. It is primarily a gimmick. It is not sufficient moly. Guard Dog (now out of business) had GD525 grease. Several other companies offer high moly stuff. Not O'Reilly or Auto Zone though.
Ted Porter is offering this: TS-60 Spine Lube
I'm sure it would do the trick and he'll ship it right to your door. You might find some other good stuff while you're on his site- fair warning!
:beer
Don't use
Don't use regular grease! It will not stay in place to do the job. What you would end up with is a nicely greased drum brake lining but little or no grease on the splines.
No, this is not something I have experienced myself, I have seen it done by others. LOL. St.
