When I replaced the clutch slave cylinder on my 02 R1150RT last month, I noticed that some brake fluid was in the chamber of the tranny that the clutch slave mounts into. I felt very luck that the problem had not caused any clutch problems, and that the amount of fluid was very small. I was wondering if there is a problem with cutting a section out of the bottom of the gasket which is between the clutch slave and the rear of the transmission to allow for any fluid the gets past the piston/cup of the slave to drain to the outside.
A "weep hole" of this type would serve two functions in my opinion. It would keep the brake fluid from building up in the chamber and being forced into the clutch area via the hollow input shaft, and also it would allow me to determine that my clutch slave was failing because I could clearly see the brake fluid running down the rear of the transmission.
Has anyone tried this trick, or does anyone have any thoughts as to why I might cause other problems that I have not thought about? I, as many, consider the design of the small throwout bearing being placed on the piston of the slave a rather dumb idea. I would much rather have a simple, tried and true cable than the set up that is on my bike. Any feedback will be very much appreciated!
