I drive a 1976 R60/6 with a hack. Had her for 12 years. 102,000 miles so far. Leaving on a 4,500 mile trip in a few weeks. Best bike I've ever had . CheersSo I'd like to join the Airhead Club.
I've determined that I need another motorcycle, with the following characteristics:
My current bike, a '16 R1200R, doesn't fit many - if any - of those points. It's a drag to ride along with the Rebel 500, as it's heavy, powerful, and loves to carve every corner. It doesn't do "slow" for anything more than creeping up to a stop sign or light, before wanting to leap forward at the first opportunity. So I started looking at other models. I think I've settled on an R60 or R75, and am currently really interested in one of the bikes advertised on the marketplace - the
- Not something that is hard to ride in a relaxed, casual, dare I say slow manner.
- Has a nice classic appearance. Possibly "cool".
- Is something that I can maintain myself, and even "needs" to be tinkered with a little bit.
- Something I can ride alongside my wife's Honda Rebel 500.
- Something that would fit in with future "Distinguished Gentlemen's Ride" events.
single owner '75 R60/6 in New York(Removed). I've run the numbers, and getting the bike out to the West Coast (I live in Long Beach, CA) works using the shipper supported by the MOA. But I haven't been able to get the seller to respond in any way.
I was wondering if anyone here might know the gentleman who listed it, or the bike itself, and might be able to help me reach out and get answers to a couple of simple questions, like is that a LWB or SWB model (not that it matters to me), roughly how many miles are on it, and is it even still available?
If anyone has other resources I should look at in choosing the right airhead for myself, I'd love more reading material.
What transport company did you use?Now just waiting on the transport company
The one linked in the Member Dicounts page:What transport company did you use?
motorcycleshippers.com
The '75 R60/6 is starting to arrive! Got the front fender...
Congratulations on the /6. That bike is about an hour from where I live. I talked to the owner. If I had the room I would have bought it. I'd say good luck with her but I don't think you'd need it with that one.
So if I understand correctly; you remove one air intake tube, insert the meter, note the airflow, the remove and do the same on the other carb until you have them matched?It was the choke piston on the slide carb on my 75 R60/6 that was the main source of my problems. When cleaning the carb I noticed a bunch of black "spooge" in the piston (see attached image). Dutifully I removed the spooge (which was the severely degraded rubber seal). I came to discover that it would only take about 12 miles with fresh spark plugs before one side would begin fouling - Pro Tip - an R60/6 running on one cylinder does not make much power - if one is fairly close to home (and lucky) it is possible to return home by jogging alongside the bike whilst in first gear, running badly on one cylinder! The excess fuel and fouling led to much carbon build-up on the pistons and valves - which contributed to pinging (and the suggestion for use of avgas) - I used a product, recommended by Oak (a now deceased airhead guru), called HydroSeal II to soak the pistons and heads to remove the carbon - along with periodic brushing with an old toothbrush to dislodge the softened carbon.
To use, the air filters (or in the case of the R60/6, the air intake tubes) are removed. The air flow meter is placed at the air intake side of the carb and the flow rate is measured. One attempts to get about the same for each carb.
Source for air flow meter -
Dual Carb Synchrometer Air Flow Meter Tool | Moore Parts
Dual Carb Synchrometer Air Flow Meter Works With Side Draft Or Downdraft Carburetors. A Must When Balancing Or Tuning Multiple Carburetors. Fast Free Shipping!www.mooreparts.com
Bing slide carb choke piston and airflow meter images below -
View attachment 116590View attachment 116589
Oh, the marker is off. One is for the northern route, the other for the southern rout. Total time is either 40 or 42 hours depending on route. Map display glitch.Western Iowa to central Colorado is about 600 miles... in two hours???
