Seeing how you are using it both ways, how do you remember which mode it's set for Mike? I'm so I like switchesI use the CanBus mode in the rear powerlet socket and it works great. I have used the standard mode to rejuvenate some ATV batteries.
I found the manual a bit "weak". Never been a fan of "touching the leeds together"Since I have a direct connection, I use it that mode. I figure the resistance is less and the charger can definitely use all of its modes.
It has never been clear to me that the charger can use all of its advanced modes via Canbus. At one time, I would have said it does not. On reading the manual again, it might but I am not sure.
I'm sure this has been asked, but, is it better to connect the Optimate 4 battery tender using the CAN-bus or the Standard mode?
