M
MarkCBouchard
As mentioned in this thread: http://forums.bmwmoa.org/showthread.php?t=28198
I had some problems with the connections into the ignition control unit. I thought the issue had been resolved but I was proven wrong today - no spark on the plugs no matter what I did. There is still the spark when I turn off the ignition so the coils seem to be OK. I checked all connections, sprayed the terminals with electronic cleaner, still no luck. I followed Clymer's instructions in section 6, when I got to step c) there was no voltage reading at all. So I guess the problem is with the control unit or the trigger unit.
Now, 7 a) says to pull terminal wire # 5 out of the connector - it is stuck. Is it supposed to slide gently out or do I have to use force? I didn't want to be too brutal in fear of tearing it off. Until I get it out there seems to be no telling if it's the control or trigger unit that has resigned. Or am I looking in the wrong places? Ideas anyone?
Balder
Balder
