Below are a list of the known recall notices and service bulletins. Where available, the appropriate reference number is provided.
Use your VIN to check for recalls against your bike - https://nhtsa.bmwgroup.com/safetyrecall/pages/motorradRecallSearch.xhtml
or here - https://www.bmw-motorrad.co.za/en/service/recall-lookup.html
Recalls
Airhead Front 19" Snowflake Rim http://robfrankham.co.uk/bike/dreaded_bmw_front_wheel_recall.htm
More About Snowflake Recall (US #84v092000) - http://bmwmotorcycletech.info/19inchrecall.htm
C600 Side Trim Fasteners (Canada #2012404) - http://www.healthycanadians.gc.ca/r...-eng.php?_ga=1.176540908.874937991.1401371044
C600 Side Trim Fasteners (US #12V556000) - http://www-odi.nhtsa.dot.gov/recall...earchtype=quicksearch&summary=true&refurl=rss
F700GS and F800GS Sidestand (US #13V279000) - http://forums.bmwmoa.org/showthread...ll-ID-No-13v279000-BMW-2013-F700GS-and-F800GS
F700GS and F800GS Sidestand (Canada #2013209) - http://wwwapps.tc.gc.ca/saf-sec-sur/7/vrdb-bdrv/search-recherche/detail.aspx?lang=eng&rn=2013209
Fuel Pump Flanges on Multiple Models (Canada #2013442 - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2013442
Fuel Pump flanges on Multiple Models (USA #13V617000) - http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM448315/RCAK-13V617-1263.pdf
Sidestand on Multiple Models (Canada #2014045) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2014045
Sidestand on Multiple Models (US #14V65000) - http://www-odi.nhtsa.dot.gov/owners...searchCriteria.nhtsa_ids=14V065000&refurl=rss
K1600GT / GTL Throttle Valve Control Software (Canada #2013369) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2013369
K1600GT / GTL Throttle Valve Control Software (US #13V526000) - http://www-odi.nhtsa.dot.gov/owners...searchCriteria.nhtsa_ids=13V526000&refurl=rss
F800ST / S Rear Wheel Bearing 2006-2009 (Canada #2013380) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2013380
F800ST / S Rear Wheel Bearing 2006-2009 (US #13V549000) - http://www-odi.nhtsa.dot.gov/owners...&searchCriteria.nhtsa_ids=13V549&refurl=email
R1200RT Leaking Brake Lines 2007-2009 (US #09V256000) - http://forums.bmwmoa.org/showthread.php?40425-R1200RT-recall&p=507775&viewfull=1#post507775
R1200GS 2013 Front Fork Locking Bolt (US #13V154000) - http://www-odi.nhtsa.dot.gov/owners...searchCriteria.nhtsa_ids=13V154000&refurl=rss
R1200GS 2013 Transmission Oil Pressure Too High (Canada #2013040) - http://wwwapps.tc.gc.ca/saf-sec-sur/7/vrdb-bdrv/search-recherche/detail.aspx?lang=eng&rn=2013040
S1000RR 2012-2013 Sidestand Attach Bolts (US #12V585000) - http://www-odi.nhtsa.dot.gov/owners...searchCriteria.nhtsa_ids=12V585000&refurl=rss
S1000RR 2012-2013 Sidestand Attach Bolts (Canada #2012428) - http://wwwapps.tc.gc.ca/saf-sec-sur/7/vrdb-bdrv/search-recherche/detail.aspx?lang=eng&rn=2012428
S1000RR 2012 Connecting Rod Bolts Loosening (US #12V177000) - http://www-odi.nhtsa.dot.gov/owners...searchCriteria.nhtsa_ids=12V177000&refurl=rss
K1200R / R Sport / S 2007-2008 Foaming Brake Fluid (US #12V487000) - http://www-odi.nhtsa.dot.gov/owners...searchCriteria.nhtsa_ids=12V487000&refurl=rss
K1300S 2012-2013 Foaming Brake Fluid (US #12V487000) - http://www-odi.nhtsa.dot.gov/owners...searchCriteria.nhtsa_ids=12V487000&refurl=rss
K1300S / GT 2009 Foaming Brake Fluid (US #09V202000) - http://forums.bmwmoa.org/showthread.php?37061-Recall-2009-K1300-GT-and-S
K1200 and K1300 Foaming Brake Fluid (Canada #2012334) - http://wwwapps.tc.gc.ca/saf-sec-sur...t=&ls=0&sy=0&rn=2012334&cf=SearchResult&pg=-1
F650GS / F800GS 2008-2009 Chain Not to Spec (US #10V274000) - http://forums.bmwmoa.org/showthread.php?48206-Recall-Campaign-10V-274-08-09-F650GS-and-F800GS-Chains
K1200GT 2007-2008 Conversion of Front Brake Lines (US #10V276000) - http://forums.bmwmoa.org/showthread.php?47256-08-GT-recall
F650 Coolant Hose Slips Off (Unpublished) - http://forums.bmwmoa.org/showthread.php?36381-Recall-Intake-hose
F650GS / F800GS 2008-2010 Coolant Hose Misrouted Internally (US #09V499000) - http://forums.bmwmoa.org/showthread.php?41982-Recall-BMW-F650GS-F800GS-2008-2010
F800GS 2008 Axle Shaft (US #09V088000) - http://forums.bmwmoa.org/showthread.php?34286-F-800-GS-Recall
R1150GSA 2003 Transmission Gears (US #02V319000) - http://forums.bmwmoa.org/showthread.php?2987-Transmission-Recall-on-GS-Adventure
EWS Ring/Aerial Various Models - http://forums.bmwmoa.org/showthread.php?27297-EWS-recalled-today
K75 / K100 / R80GS 1986 Spring Damper Eyelet Crack (US #87V193000) - http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/ACM41871/RC-87V193-NN.PDF
K75 / K100 1985-1986 Throttle Cable (US #86V080000) - http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/ACM40499/RC-86V080-NN.PDF
K1300GT / S 2009-2010 Engine Stalling at Idle (US #09V471000) - http://forums.bmwmoa.org/showthread.php?41612-Recall-BMW-K1300GT-and-K1300S-2009-2010
K1300GT / S 2009 Handlebar Switches (US #09V384000) - http://forums.bmwmoa.org/showthread.php?40204-Recall-2009-K1300-GT-and-S
R1200GS 2006-2008 Poor Sealing of Fuel Pump (US #09V319000) - http://forums.bmwmoa.org/showthread.php?38676-Recall-BMW-R1200GS-2006-2008
F650GS 2007 Front Brake Fastener Torque (US #10V496000) - http://forums.bmwmoa.org/showthread...-2007-2010-NHTSA-Campaign-ID-number-10V496000
K1200/1300 Various Models 2004-2010 Front Suspension Bearings (US #10V488000) - http://forums.bmwmoa.org/showthread...-2004-2010-NHTSA-Campaign-ID-number-10V488000
R1200R/R1200ST/R1200GS/GSA Various 2006-2007-2008 Brake Line Routing (US # 08V254000) - http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/ACM9707490/RCAK-08V254-3329.pdf
R1200GS 2012-2013 Leaking Gearbox Seal Ring (Canada #2014144) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2014144
R1200GS 2013 Internal Transmission Pressure (Canada #14V211000) - http://www-odi.nhtsa.dot.gov/owners...searchCriteria.nhtsa_ids=14V211000&refurl=rss
C600 Sport / C650GT 2013-2014 Cam Chain Tensioner (Canada #2014179) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur...ft=&ls=0&sy=0&rn=2014179&cf=SearchResult&pg=0
R1200RT 2014 Suspension (US #14V320000) - http://www-odi.nhtsa.dot.gov/owners...LTXdFLyK2XlQRfSyQTyGsb2MPKwGdn4gPv!-825421616
R1200RT 2014 Suspension (Canada #2014222) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur...ft=&ls=0&sy=0&rn=2014222&cf=SearchResult&pg=0
R1200/K1200/K1300/HP2 Various 2005-2011 Holes in Rear Wheel Flange (Canada #2015101) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur...ft=&ls=0&sy=0&rn=2015101&cf=SearchResult&pg=0
R1200/K1200/K1300/HP2 Various 2005-2011 Holes in Rear Wheel Flange (USA #15V141000) - http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs/download/doc/UCM475387/RCAK-15V141-4032.pdf
G650GS & Dakar 2013-2016 Engine Stalling (Canada #2016478) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2016478
G650GS & Dakar 2013-2016 Engine Stalling (US #16v689000) - http://www-odi.nhtsa.dot.gov/owners...searchCriteria.nhtsa_ids=16V689000&refurl=rss
C600 Sport and GT 2012-2015 Front Brake Hose Cracking (Canada #2015527) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2015527
R9T 2014-2015 Lighting System and Retroreflective Devices (Canada #2016417) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2016417
R9T 2014-2015 Lighting System and Retroreflective Devices (USA #15V110000) - http://www-odi.nhtsa.dot.gov/owners...searchCriteria.nhtsa_ids=15V110000&refurl=rss
S1000R/XR 2016 Loose Bolt on Rear Suspension (Canada #2017001) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2017001
S1000R/RR 2016-2017 Loose Bolt on Rear Suspension (USA 16V948000) - https://www.nhtsa.gov/recalls?nhtsaId=16V948000&refurl=rss#recalls300
R9T/K1600GT 2017 Noise Emissions (Canada #2017082) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2017082
G310R 2018 Lighting System and Retroreflective Devices (Canada #2017329) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2017329
R1200GS/GSA 2014-2017 Front Fork Separate from Triple Clamp (US #17V438000) - https://www.nhtsa.gov/recalls?nhtsaId=17V438
R1200GS/GSA 2013-2017 Front Fork Separate from Triple Clamp (Canada #2017343) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur...ft=&ls=0&sy=0&rn=2017343&cf=SearchResult&pg=0
R1200GS/GSA 2013-2017 Front Fork Separate from Triple Clamp (Australia #2017/16184) - https://www.productsafety.gov.au/recall/bmw-ag-bmw-r-1200-gs-bmw-r-1200-gsa
Various R1200/F800/S1000 2013-2017 Lighting Systems and Reflective Devices (Canada #2017376) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2017376
Various R1200/F800/S1000 2013-2017 Reflective Devices (USA #17V481000) - https://forums.bmwmoa.org/showthread.php?89880-BMW-and-NHTSA-rear-reflex-reflector-recall-issued
R1200RT Police 2014-2017 Brake Light May not Illuminate (USA #17V488000) - https://forums.bmwmoa.org/showthrea...g-certain-2014-2017-R1200RT-Police-motorcyles
R1200RT Police 2014-2016 Brake Light May not Illuminate (Canada #2017390) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2017390
G310R 2017 Handlebar Not Secured (Europe #A12/1112/17) - https://ec.europa.eu/consumers/cons...112/17&exclude_search_term=0&search_year=2017
R9T Frame Pivot Pin May Not Be Tight (Canada #2017399) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2017399
C650GT/Evolution 2017 Front Wheel Rim may be Missing Markings (USA #17V467000) - https://forums.bmwmoa.org/showthrea...2017-BMW-C650-GT-and-BMW-C-Evolution-scooters
R9T 2014-2017 Bolts Connecting Right-side Swingarm Pivot Pin to Frame May Loosen (USA #17V502000) - https://forums.bmwmoa.org/showthrea...-Campaign-Number-17V502000-2014-2017-R-NINE-T
R9T 2014-2017 Bolts Connecting Right-side Swingarm Pivot Pin to Frame May Loosen (Australia 2017/16287) - https://www.productsafety.gov.au/re...td-k21-0a06-0a16-k21-11-0j01-0j03-motorcycles
Multiple Bikes-Multiple Years Accessory turn signals may not comply with the requirements (Canada #2017428) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/detail.aspx?lang=eng&rn=2017428
G310R 2017 Front Brake Caliper is not Correctly Secured (EU #A12/1200/17) - https://ec.europa.eu/consumers/cons...200/17&exclude_search_term=0&search_year=2017
F800GT/R 2014-2018 Rear side reflex reflector mounted to the license plate bracket may be partially blocked (Canada #2017462) - http://wwwapps.tc.gc.ca/Saf-Sec-Sur...ft=&ls=0&sy=0&rn=2017462&cf=SearchResult&pg=0
F800GT/R 2014-2018 Rear side reflex reflector mounted to the license plate bracket may be partially blocked (USA #17v591000) - https://www.nhtsa.gov/recalls?nhtsaId=17V591000&refurl=rss#recalls370
2016 R9T and F-Series and Scooters Malfunction indicator light is not activated properly (Australia 2017/16498) - https://www.productsafety.gov.au/re...f-800-gs-f800-gs-adventure-r-nine-t-scrambler
2017/2018 G310R and 2018 G310GS Side Stand or Frame Damage [USA #18V408000] - https://forums.bmwmoa.org/showthrea...10GS-and-G310R-models-NHTSA-Campaing18V408000
2019 F850GS Engine connecting rods might loosen (USA #18V830000) - https://advrider.com/bmw-have-a-maj...utm_campaign=editorial&utm_content=12_11_2018
2013-2018 600 Sport/650GT Scooter Front brake hose could crack [Canada #2019109] - http://canadamotoguide.com/2019/03/08/bmw-recall-20/
2018-2020 G310GS/2017-2020 G310R Front and rear brake caliper pistons may corrode (USA #19V593000) - https://www.nhtsa.gov/vehicle/2018/BMW/G310%2520GS#recalls
2015-2019 K1600GT/GTL/B Rear wheel lock up (Europe #A12/1575/19) - https://ec.europa.eu/safety-gate-alerts/screen/webReport/alertDetail/389756
2017-2020 K1600GT/2018-2020 K1600GTL/B Rear wheel lock up (USA #19V692000) - https://www.nhtsa.gov/recalls?nhtsaId=19V692
2019 C400 Scooter Throttle Cable Freezes (Canada #2020060) - https://wwwapps.tc.gc.ca/Saf-Sec-Su...ft=&ls=0&sy=0&rn=2020060&cf=SearchResult&pg=0
2018-2020 G310Gs/R 2019 C400 Front/Rear Calipers Corrode (Canada #2019405) - https://wwwapps.tc.gc.ca/Saf-Sec-Su...ft=&ls=0&sy=0&rn=2019405&cf=SearchResult&pg=0
2019-2020 R1250RT Missing brake fluid cap (USA #20E013000) - https://www.nhtsa.gov/vehicle/2020/BMW/R%25201250%2520RT#recalls
2018-2020 R9T/Scrambler Missing brake fluid cap (USA #20V166000) - https://www.nhtsa.gov/vehicle/2020/BMW/R%25201250%2520RT#recalls
2020 R1250R/RS Missing brake fluid cap (USA #20V166000) - https://www.nhtsa.gov/vehicle/2020/BMW/R%25201250%2520RT#recalls
2019-2020 R9TPure Missing brake fluid cap (USA #20V166000) - https://www.nhtsa.gov/vehicle/2020/BMW/R%25201250%2520RT#recalls
2019-2020 R1250GS/GSA/RT Missing brake fluid cap (USA #20V166000) - https://www.nhtsa.gov/vehicle/2020/BMW/R%25201250%2520RT#recalls
2018 R9T Racer Missing brake fluid cap (USA #20V166000) - https://www.nhtsa.gov/vehicle/2020/BMW/R%25201250%2520RT#recalls
2020 R1250GS/RT Loose final drive pivot pin (USA #20V165000) - https://www.nhtsa.gov/vehicle/2020/BMW/R%25201250%2520RT#recalls
2019/2020 R1250GS/GSA/RT and 2020 S1000RR/XR Front brake calipers may leak (USA #20V476000) - https://www.nhtsa.gov/recalls?nhtsaId=20V476000&refurl=rss
2009-2011 K1300S/GT Fuel pump cover may leak (USA #20V47100) - https://forums.bmwmoa.org/showthread.php?98670-Hexhead-Fuel-Pump-Recall-new-one
2019-2020 K1600B/GT/GTL Rear suspension link may fail (USA #22V023) - https://static.nhtsa.gov/odi/rcl/2022/RCAK-22V023-9744.pdf
2017-2020 K1600B/GT/GTL Gear change could lock up (EU Alert #A12/01513/22) - https://ec.europa.eu/safety-gate-alerts/screen/webReport/alertDetail/10006911
2022 S1000RR/M1000RR and 2022-2023 S1000XR/S1000R Clutch cover can loosen and leak oil (USA #22V752) - call 800-525-7417 [See MOA News January 2023]
2019-2023 R1250GS/GSA/RT/RTP Gearbox input shaft may break (USA #23V011) - https://forums.bmwmoa.org/showthread.php?103611-Gearbox-Imput-Shaft-Recall
2022-2023 S1000R/2020-2023 S1000XR Riding Mode Feature Inadvertently Deactivated (USA#23V051) - https://www.nhtsa.gov/vehicle/2022/BMW/S%25201000%2520XR#recalls
2020 K1600B Transmission may cause rear wheel lock up (USA #19V692) - https://www.nhtsa.gov/vehicle/2020/BMW/K1600B#recalls
2023 R1300GS Starter relay may overheat (USA #V24V557) - https://www.nhtsa.gov/vehicle/2024/BMW/R%25201300%2520GS#recalls
New 2021-2024 R18 Overheated reverse gear unit (USA #24V716000) - https://www.nhtsa.gov/?nhtsaId=24V716000
Service Bulletins
Oil Level Sensor (no model listed) - http://forums.bmwmoa.org/showthread.php?67833-Recall
Search for Recalls Here
US - http://www-odi.nhtsa.dot.gov/owners/SearchSafetyIssues
Canada - http://wwwapps.tc.gc.ca/Saf-Sec-Sur/7/VRDB-BDRV/search-recherche/menu.aspx?lang=eng
UK - http://www.vosa.gov.uk/vosa/apps/recalls/default.asp
EU - http://ec.europa.eu/consumers/safety/rapex/alerts/main/index.cfm?event=main.search
Australia - https://www.productsafety.gov.au/recalls
New Zealand - https://www.vehiclerecallsafety.nzta.govt.nz/
VIN Specific Recalls - https://nhtsa.bmwgroup.com/safetyrecall/pages/motorradRecallSearch.xhtml
Recalls
Service Bulletins
