I begin the process of dismantling the front fairing of my new-to-me 2000 R1100RT to repair shark-fin damage from previous owner. While the unit is off, I’ve decided to update the dash lighting to LED. I have found the proper replacements thanks to another post on this fabulous forum; I would like to get them ordered asap.
From the looks of the dash, I am guessing I would need approximately 14 to complete the process, that sound about right?
Also, I believe I read somewhere that the dash light for the charging unit needs to stay incandescent and should not be changed to LED. Is someone able to verify that? Also assuming that bulb to be the one with the pic of the battery on it..? Just double checking…
Last item; I also recall reading somewhere that one can change the wattage for that little incandescent bulb for the charging unit from the stock 1.5 to a 3, which then had some affect on the charging process.
Did I get that correct..??
Thank you!
Thank you!
